Help on coupe inside door finish - NCRS Discussion Boards
  • Bob H.
    • July 31, 2000
    • 821
    Hi
    My car is maroon with black interior. Should the inside of the door around the window be gloss black or another shade?
    Thanks in advance for your response.
    Bob
  • Stephen L.
    • May 31, 1984
    • 3162
    Re: Help on coupe inside door finish
    Satin black
    • Bob H.
      • July 31, 2000
      • 821
      Thanks . The trim around the headliner, etc is currently gloss. Should it be satin as well?
      • Stephen L.
        • May 31, 1984
        • 3162
        Yes. The area of the door opening at rear door edge should be body color in the door opening and satin black on the interior. Basically you tape that metal piece down the center so that with the door closed only the black will show. All painted interior trim will be the same including the plastic "halo" piece.
        The window paint line will be as in the photo
        • Bob H.
          • July 31, 2000
          • 821
          Thanks for the pics. That makes is very clear.
          Bob
