Frame C1 - NCRS Discussion Boards
Frame C1
  • Hans B.
    • September 26, 2011
    • 8
    Frame C1
    Hello everybody,
    I'm going to start with the restore of my 1961 C1 Corvette.
    To start i'll need a complete new Frame becouse of the rust on the original.
    Can enyone tell me who can deliver a good new frame?
    Her from you,
    Hans van Boxtel
  • Paul J.
    • September 9, 2008
    • 2091
    Re: Frame C1
    I hear that Vette Products in Michigan is good.
    https://www.forums.ncrs.org/showthre...frame&uid=3677
    https://www.forums.ncrs.org/showthre...frame&uid=5466
      • 6947
      Re: Frame C1
      Shipping cost to the Netherlands may cost a pretty penny, along with the cost of a new the frame. But these guys(Vette Products) have the original GM tooling to produce a frame that is close as you'll come by.
        Re: Frame C1
        Hans -
        Here's a C1 ('58) new frame from Vette Products of Michigan, stamped and assembled on the original GM dies and tooling; they're the only supplier of GM-licensed reproduction frames. The front suspension crossmember is a restored original - they don't make those.
        www.vetteproducts.net
        • George W.
          • May 31, 2000
          • 544
          Re: Frame C1
          Hans,
          I sernt you an e mail.
          I have a completly restored C1 rolling chassis that should interest you.
          George
          geopar@gvtc.com
          210 748 4693
          • Hans B.
            • 8
            Re: Frame C1
            Hello,
            Thank you for response on my message about a frame for C-1 corvette.
            I have ordered one by vetteproducts in Michigan.
            Hans
            • Tom P.
              • April 1, 1980
              • 1815
              Re: Frame C1
              Hans -
              Some additional information for those who may not know.
              The 49-54 passenger car front cross member/suspension is for the most part, identical to the 53-62 Vette frontend.
              Yes, there are a few variations, but they are minor. The most important part, the bare cross member, is a 100% swap. The top of the 49-51 cross member has 2 holes for engine mounts and ALL of the 49-54 cross members have a hole in the top/center of the cross member for a steering arm. BUT ALL OF THESE HOLES ARE COMPLETELY COVERED BY THE FAN SHROUD! (a person COULD have the holes welded over then grind and smooth the welds) So, once the car is completely assembled, not even the best judge is likely to see them. All of the pass car and Vette A-frames and suspension members are the same, EXCEPT, the 53-54 pass car spindle supports (uprights) have the knuckle for the kingpin positioned 1in higher up on the support. The tierods, left and right steering arms and the center steering arm are unique to the Corvette.
              So if a front cross member and associated parts are needed, a person will pay a LOT LESS money for pass car parts .
              • Mike E.
                • February 28, 1975
                • 5139
                Re: Frame C1
                Also, the drag link on a passenger car front end has two short end sections, while the Corvette drag link has a similar short length, but the other end is a longer one, and seems to be Corvette only.
