Problems everytime I turn left? - NCRS Discussion Boards
  • Jorn J.
    • October 21, 2008
    • 142
    Hi Friends
    Everytime I turn left are the engine doing like the ignition are failed ore it's getting no Gas and after 15 sec. all is back to normal and there is no problem if I turn right or driving on the highway??
    I think I have read about this problem before but can't find any Thread!!
    Regards Jorn
  • William C.
    • May 31, 1975
    • 6037
    Re: Problems everytime I turn left?
    Take a look at the wiring in areas that might move under the stress of a turn. First place I would start to check.
    Bill Clupper #618
    • Tom H.
      • December 1, 1993
      • 3440
      Jorn:
      Just out of curiosity, is it actually the turning left that causes the problem or is it the activation of the left turn signal ?? Just wondering if the signal switch could be part of the issue ?????
      Tom Hendricks
      Proud Member NCRS #23758
      NCM Founding Member # 1143
      • Jorn J.
        • October 21, 2008
        • 142
        Hi Tom
        Its only when I turn left with some speed and not if I turn left smooth and if I turn left with the signal switch and still drive right ahead
        Jorn
        • Jorn J.
          • October 21, 2008
          • 142
          Hi Bill
          I have looked around and all seems to be normal(new Wiring)
          Jorn
          • Tom H.
            • December 1, 1993
            • 3440
            Motor mounts OK ??
            Tom Hendricks
            • Jorn J.
              • October 21, 2008
              • 142
              Originally posted by Tom Hendricks (23758)
              Motor mounts OK ??
              New mounts and a rebuilt engine this year
                • 6960
                Jorn, Try wiggling the wiring harness connections or harness under the hood area and see if you can make it happen while the engine is running with car just sitting still. It has to be something electrical.
                • Michael H.
                  • January 29, 2008
                  • 7477
                  Originally posted by Jorn Jarnved (49584)
                  Hi Friends
                  Regards Jorn
                  Carburetor (if so equipped) dumping fuel on turns?
                  • Joseph K.
                    • August 26, 2008
                    • 407
                    Re: Problems every time I turn left?
                    I agree. If everything returns to normal after fifteen seconds it sounds like a fuel issue. It would be good to know whether it stumbles or just cuts out during the turn.
                    • Jorn J.
                      • October 21, 2008
                      • 142
                      It "stumples" if thats mean don't stopping! And if I not are giving full speed on the pedal when it starts stumples then it will stop/die.
                      My wiring harnes under the hood are super and no "loose" ends.
                      Jorn
                        • 6960
                        Jorn
                        Jorn, I think that Mike Hanson may have the right Idea, It sounds like the float level in carburator maybe to high and is be drawn into the carburator around cornors.
                        • Jorn J.
                          • October 21, 2008
                          • 142
                          OK Edward and all
                          I will stay focus on the Carb. and see what i can do
                          Thanks for sharing my problem
                          Jorn
                          • Clem Z.
                            • January 1, 2006
                            • 9427
                            if it is a WCFB you could be sucking fuel into the choke vacuum port if the little brass tube in the float bowl is missing
