For your C1 - NCRS Discussion Boards
For your C1
  • Tim S.
    • May 31, 1990
    • 715
    For your C1
    Neat! Can't afford it, but neat!
  • Tom P.
    • April 1, 1980
    • 1826
    Re: For your C1
    Something to be aware of.
    The 56 and 57-62 axles, axle bearings, bearing retainers and axle housings are NOT the same. Thus, you either use 56 axles, bearings and retainers in a 56 housing, OR, 57-62 parts in a 57-62 housing. Those of you who are intimately familiar with these early axles/housings know this, others may not be aware of the specific differences.
    Also, it is not specified if those front hubs will fit the STANDARD,STOCK front spindles, OR, if they only fit the spindles that were originally on Vettes that got the GENUINE Halibrands.
    John Neas is considerably more familiar with these differences than anyone else (he has TWO cars with Halibrands).
    • Bruce B.
      • May 31, 1996
      • 2930
      Re: For your C1
      At least this set is a little less expensive then the ones in the Driveline for $85,000.00.
