What is this bracket for? - NCRS Discussion Boards
  • D S.
    • March 1, 2005
    • 1551
    This bracket is riveted to the underside of the passenger side hood gutter on my '70 and seems to serve no purpose that I am aware of. Unless someone tells me what it is for. It is located near the fan motor casing.
    Scott Sims
    Texas Chapter
  • Ken P.
    • 77
    Re: What is this bracket for?
    Looks like the, windshield washer bottle, bracket.
    • Tom H.
      • December 1, 1993
      • 3440
      Bingo !!! Here's the one from my 71
      Tom Hendricks
      Proud Member NCRS #23758
      NCM Founding Member # 1143
      • D S.
        • March 1, 2005
        • 1551
        Thanks! But my March built 1970 already has a windshield washer bag on the driver's side so I assume it was installed there as a routine assembly process. I knew it had to be screwed to something as the oval slot looked like it. Another oddity was when I had the engine out I found a windshield wiper relay mounted on the inside of the passenger side lower inner fender with no hoses attached to it. I already have the one on the driver's side firewall.
        I appreciate y'all clearing that one up for me.
          • 6960
          Scott, could it have been possible the was a front nose from a 72 put on your 70, the wiper relay was moved at some point to the inner fender, as was my 72 it is mounted on the pass. inner fender.
          • D S.
            • March 1, 2005
            • 1551
            No, the 1970 AIM shows a wiper door relay being mounted there but was canceled due to the relay installation being moved to the firewall.
