Hardtop weatherstripping - NCRS Discussion Boards
  • Steve V.
    • June 27, 2011
    • 95
    Does anybody have instructions on how to replace all the weatherstripping on a hardtop?
    Thanks, Steve
    Opportunity is missed by most people
    because it is dressed in overalls and looks like work.
    Thomas Edison
  • Don H.
    • December 1, 1981
    • 1500
    Re: Hardtop weatherstripping
    The header and around the door windows is pretty straight forward so I assume you mean the rear deck. This is a one piece gasket which includes where the hardtop meets the deck lid and around the rear window. This is not an easy job but can be done. I would only do it if replacing the rear window, full hardtop resto, or if it was in VERY bad shape. Good luck, Don H.
    • Philip P.
      • February 28, 2011
      • 558
      This is worth watching.. some good tips
      Hope this helps
      Phil
      • Steve V.
        • June 27, 2011
        • 95
        Thanks for the replys. The part that concerns me is the side rail vertical weatherstrip as it appears to be riveted to the side window retainer. Is that correct? How do I remove the retainer which appears to be riveted in place also? Any suggestions?
        Steve
        Thomas Edison
        • Philip P.
          • February 28, 2011
          • 558
          Here is the page from the ST-12 for the side window,
          Phil
          • Bruce B.
            • May 31, 1996
            • 2930
            A number of rivits on the C1 hardtops are stainless steel. They are very difficult to drill and you will find some of them bent over not bucked.
            To replace them with stainless rivits is just as if not more difficult then removing them.
            That is why you see pop rivits on many hardtops.
            • Steve V.
              • June 27, 2011
              • 95
              Thanks Phillip and Bruce,
              Now I have the information I need to proceed (carefully) with replacing the weatherstriping.
              Steve
              Thomas Edison
