54 Rear End Bearings - NCRS Discussion Boards
  • Gary B.
    • July 31, 1979
    • 926
    Does anybody have the bearing numbers for the rear differential bearings, specifically the carrier bearings and the pinion bearings? Would like to try and buy at a industrial supply, lower cost. Also, anybody have a pinion seal part number also?
    Gary
  • Dick W.
    • 10483
    Re: 54 Rear End Bearings
    Boz, if you have the GM numbers you can go to NAPA, Carquest, etc website and get the cross reference.
    BTW, Terry send you the pictures of Dipstick's Metro?
    Dick Whittington
    • Mike M.
      • May 31, 1974
      • 8382
      some one should post a pic of the dipstick's latest atrocity. heaven help sondra. mike
      • Dick W.
        • 10483
        Dick Whittington
        • Gary B.
          • July 31, 1979
          • 926
          1971 Parts book shows the following for numbers...
          Front Pinion Bearing, GM #954780, ND5306W x 1730A
          Rear Pinion Bearing, GM#125630, Hyatt 1506
          Carrier Bearings, GM#127861, Hyatt 11360, race is Hyatt 11360Z
          Does not list a front seal, but Corvette Central does.
          Tried NAPA, they do not cross-reference these numbers, "nothing found".
          It appears the front pinion bearing is still available from GM, I'll call them today.
          I'll also call local bearing supplier and see if they can cross-reference to newer bearings.
          Yes, I did get the pictures Dickie. Quite a car. I'm jealous!
          Gary
