how is the 67 grille supposed to look? - The leading edge around complete grille polished chrome, then the vertical lines polished chrome, are the leading horiziontal edges of the egg crate supposed to be polished chrome as well or painted the silver/gray like the crate walls? Thanks Jim (hope this is clear)
67 Grille
Re: 67 Grille
The problem with the ones currently available is that they vary in the amount of overspray on the chrome. On the last one I saw all the chrome was pretty much covered with the overspray. You can use lacquer thinner and steel wool to remove the overspray, but it is tedious and time consuming. Richard Fortier may be willing to clean yours up.- Top
Re: 67 Grille
Here is a pic of a replacement grill I bought for my '67 from GMparts. I'm pretty happy with it, the chrome is very good and there is no overspray. Most used ones I looked at had the center tab broken off.Attached Files- Top
