I have a maintenance free Restoration Battery in my '67 along with a Battery Minder Charger. On the charger is a desulfation button. Do maintenance free batteries need desulfation? Thanks, Patrick
Restoration Battery Question...
Tags: None
- Top
Re: Restoration Battery Question...
PT,
I don't think so. I have a 67 Restoration Battery and I just keep it on a Battery Tender all the time when it is sitting for a week or 2. Haven't had a problem for 4-5 years or so. Keeps the clock running and is always at full charge when I start.
I think sulfation or desulfation is more of a problem with lead acid batteries open to the atmosphere.
Check this out:
Regards,Jerry Fuccillo
1967 327/300 Convertible since 1968- Top
Thanks Jerry, I thought I had read that some years ago here but wanted to make sure. I keep my charger plugged in on the battery 24/7, also to keep the clock running. I'm told that if the clock sits idle for extended periods of time, the lubrication will drain off the gears. PT- Top
The original clock is an electro-mechanical device. It has gears, bearings and contact points. IMHO, the more you use the contact points, once every 2 minutes or so, the shorter the overall life of the clock. They have a "life expectancy" of "X" number of operations. I prefer to let the clock sit idle and only operate when the battery is connected. I use a disconnect switch on the battery.- Top
I have all my restoration batteries (4) on a Battery MINDer plus, which has the button. However, whenever the batteries get to full charge that maintainence light (green) starts blinking whether or not you push the button.Big Tanks In the High Mountains of New Mexico- Top
