Change Rear end lubricant- C-2 - NCRS Discussion Boards
  • Herb P.
    • April 19, 2011
    • 37
    What is the best way to change the rear end lubricant on a C-2? Specifically, how does one easily get the old fluid out?
  • Brian M.
    • February 1, 1997
    • 1842
    Re: Change Rear end lubricant- C-2
    I've used a suction gun.
    • Frank E.
      • May 31, 1986
      • 189
      Suction gun. You can buy it anywhere automotive....
      Frank
      1966 Milano Maroon Roadster
      2004 CE Z06
      • Brian M.
        • February 1, 1997
        • 1842
        Most FLAPS will carry them.
        • Gary R.
          • April 1, 1989
          • 1804
          small drill gear pump will work as well.
          • Herb P.
            • April 19, 2011
            • 37
            What is a FLAPS?
            • Robert G.
              • May 31, 1990
              • 429
              Friendly Local Auto Parts Store
              • Kevin N.
                • September 30, 2002
                • 88
                ditto on the suction gun. to make it go alot easier...drive the car for awhile to heat up the old gear lube. it siphons out more easily.
                in garage now...1991 Z07 coupe... ex-garagers...64cp, 65cvt, 66cvt, 66cvt, 66cp, 66B.B.cp, 67cp, 67cp, 67cp, 69B.B.cp, 69cp, 69cp, 69cp, 70cp, 70cp, 70cvt, 71cp, 71LT1cp, 72cp, 72LT1cp, 72cvt, 73L82cp, 73cp, 73L82cp, 74L82cvt, 74cp, 78s.a.cp, 79cp, 84cp, 85cp(twice), 88cp, 89cvt, 91cvt, 96cp, 96LT4cp, 98cvt, 99frc, 00frc, 00cp, 01cvt, 04cvt, 04Z06
                • Herb P.
                  • April 19, 2011
                  • 37
                  Thanks all. Off to get a suction pump.Might as well take the Vette to warm up the rear end lubricant at the same time.!
                  • Herb P.
                    • April 19, 2011
                    • 37
                    Suction gun, not pump.
                    • Jim T.
                      • March 1, 1993
                      • 5351
                      Removing the right rear tire helps when I have done my 68 and 70. I can also lower the left rear without the rear tire on to pool the fluid.
