Is there any difference between a coupe door and a convertible door on a C3 other than the glass, weatherstrip and alignment pin housing? What I am trying to find out is, if I take my pin and housing and transfer it to a coupe door from a convertible door, will it fit the same way? I have been trying to find a replacement convertible door because my inner sheet metal is unrepairable, with no luck. Coupe doors in good shape our readily available, on the otherhand.
1971 doors
Re: 1971 doors
Frank,
There have been earlier threads on this subject, but if you can find a decent coupe door, you will have to add the metal plate for the guide pin that convertible doors have.
Have seen this plate available from the major parts suppliers.
BTW -on '73 and newer, the door will have the added safety beam as part of the metal underskin structure.
Once that is done, you can then- Top
Re: 1971 doors
Bob, Just an FYI. We have seen that safety beam on a few VERY late (last couple of days of production) 1972s. And if you know where to look you can see the edges of it in the door jamb -- on the door of course.Terry- Top
