I am in the process of assembling the front suspension on my 1954 and needed a little help here on a couple torque settings. Having trouble pinning down the torque setting for the following....
1) Lower control rod shaft bolts that hold the shaft to the front crossmember.
2) Third arm assembly that bolts to the front crossmember - 4 bolts
What torque specs I have found for the front end bushings are:
Lower inner bushings at 85-100
Lower outer bushings - pivot bolt at 100-200
pivot nut at 90-120
Upper inner bushing at 30-40
Upper outer bushing at 30-40
Stabilizer bracket to frame at 17-22
Lastly - regarding the metal wedge plates that can be ordered to go between the frame and the front crossmember to help with alignment found on the later models .... is this a good idea to install a set?
Thanks for your help!
John
pivot nut at 90-120
John
