What type of coil spring comression tool works best ? Should I buy the tool that goes inside the spring or one that fits on the outside of the spring?
1958 coil spring compression tool
Tags: None
Re: 1958 coil spring compression tool
Brandon,
Search the archives for some good information. A piece of 1/2" threaded rod can be used to compress the spring. It gets installed thru the center of the spring with some blocks on the end.
Dennis- Top
Indeed I am in the process of rebuild of the front end of my 1954 and using the 1/2" threaded rod and have not had a problem - but as mentioned it may help with a little piece of mind to have a "safety chain" installed on the coil.
Good luck!
John- Top
Scroll through here until you find it. I put this together over a year ago.
It will take more time to explain it than it will for you to look at the pictures.
http://www.chevytalk.org/fusionbb/sh...hp?tid/218134/- Top
Absolutely! I used a short wire rope sling and made sure it was secured.
Dennis- Top
