54 oil gauge line install - NCRS Discussion Boards
  • Guy M.
    • November 1, 1993
    • 500
    Has anyone installed this line from CC? Looks like it needs flared going into the block but with nothing for the flared end to seat to wont it leak? Or will the fitting tighten around the line sealing it? Same at gauge end? Thanks as always
  • Gary C.
    Administrator
    • October 1, 1982
    • 17659
    Re: 54 oil gauge line install
    Guy,
    Not sure what size line CC is selling. Paul Mazut has the correct line and fittings. Original line size was 3/32"
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Guy M.
      • November 1, 1993
      • 500
      Thanks Gary, Im just needing to know if the ends need flared. Thanks for the link, I believe thats what I have.
      • Cathy S.
        • August 31, 2003
        • 293
        The CC line and fittings works great. The line does not need to be flared. The fitting that comes with the line is a compression fitting and seals/flares the line end upon tightening.
        • Guy M.
          • November 1, 1993
          • 500
          Thanks so much!!!
