1972 original color for shocks - NCRS Discussion Boards
  • Jerome P.
    • October 22, 2006
    • 607
    The TIMJG states the shocks are painted a semi-gloss grayish blue. What manufuacture makes the closest match and where can I purchase?
    Thanks.
    • 6950
    Re: 1972 original color for shocks
    Jerome, I used quanta shock paint. I think that it may be hard to match the original gray paint using a rattle can. I f you know of someone that may have a original shock to use to try and get a color that maybe close.
    • Jerome P.
      • October 22, 2006
      • 607
      Re: 1972 original color paint for shocks
      Ed, I looked at Quanta's website and they have the grayish-blue spray paint. However it appears they only ship ground transportation. (7-10 days) Do you know or does anybody know of a close equivalent that can be purchased locally. I am short on time.
        • 11669
        I just went to Lowe's and bought the closest blue/gray I could find, and it worked well.
        We chassis judges are not THAT picky on the color.
        Patrick
        • Paul O.
          • August 31, 1990
          • 1716
          Jerome
          I am in Chicago right now will try to check what brand and number for some gray paint I found a while back just bear with me till Sunday. When I return to Cincinnati. Like Patrick said we are not that hard on shock color.
          Paul 18046
          • Don L.
            • August 31, 2005
            • 1005
            Patrick and Paul liked the blue-grey on mine at this year's national judging. I'm certain that I still have what's left of the spray can at home. I'm pretty sure it was a local purchase.
            Look for another post from me on this later. I'll let you know what the paint is and I think I have a pic of the finished product too. BTW, there are white paper broadcast codes afixed to the shocks - 1 code for front and another for rear. I'll let you know what the 2 letter alpha codes are in my next post.
            Don Lowe
            NCRS #44382
            Carolinas Chapter
            • Paul O.
              • August 31, 1990
              • 1716
              I remember the company is Seymour paints and the paint is the HI Tech Enamel it is I think the dark gray 16-117 here is their web site for this spray can.
              Paul 18046
              • Mike G.
                • July 31, 2002
                • 709
                here is what it should look like
                • Don L.
                  • August 31, 2005
                  • 1005
                  Jerome, I see that Mike has posted a photo of an original shock, giving you the color to duplicate. I checked my paint stash and found that the paint I used was indeed a local purchase. The unfortunate news for this thread is that Paragon is local for me. I bought the exact paint that Paul is referencing and pointing you to (Seymour HI-TECH). If you are in a hurry and can't take the time to order and wait for shipping, I suggest you print the color sample from Seymour's web page and take it to you local paint supply or home goods store and get the closest color you can in a semi-gloss finish.
                  As for the broadcast code decals, I made mine on the computer. The JG calls for std suspension '72 shocks to be coded PE (front) and PY (rear). I printed mine on white address labels and cut to size and shape. They worked fine and judged with no deduct.
                  I hope this helps...
                  Don Lowe
                  NCRS #44382
                  Carolinas Chapter
                  • Jerome P.
                    • October 22, 2006
                    • 607
                    Last Friday I was able to find an original '72 shock and cleaned it up and took it to a Company called Space Age Auto Paints. They were able to match the paint and give me 2 aerosol spray cans of matching paint. Turn around time 12 hours. I think they are owned by U-Haul.
                    I am very satisfied.
                    Thanks to all for your help and input.
                    Space Age Auto Paint Store Inc
                    707 S Country Club Dr, Mesa, AZ 85210
                    (480) 835-0971
