Electrical problem in my 62 - NCRS Discussion Boards
  • Mike P.
    • December 28, 2010
    • 27
    When the brake is applied or when the turn signal is activated the gas gauge indicator moves. I checked the grounding on the tail lights and found no problem. I have not checked the gas tank ground. Any suggestions will be appreciated
  • John T.
    NCRS Financial Officer
    • January 1, 1983
    • 293
    Re: Electrical problem in my 62
    Most common solution is to add a dedicated ground for the gas tank. This is not visible when judged and will usually solve the problem.
    Hope this helps.
    John
    • Richard T.
      • February 1, 1979
      • 858
      Very common, as John said a dedicated ground is needed. Run a wire from one of the screws used to retain the sending unit in the tank to a clean spot on the chassis. Rich
      • Mike P.
        • December 28, 2010
        • 27
        Thanks guys. I'll give it a try.
        • John F.
          • March 23, 2008
          • 2424
          The extra ground solderd to the sending unit looks like this. Go to raecorvettes.com and see the tech article by Joe Calcagno. He taught a class on 62s at BG a few years ago.
          John F
          • Mike P.
            • December 28, 2010
            • 27
            Thanks John, I will check it out.
            Mike
            • Mike P.
              • December 28, 2010
              • 27
              John,
              I can't find www.raecorvettes.com.
              Could it be something else?
              Mike
              • Dennis C.
                • June 30, 2002
                • 888
                Mike,
                This is the web site.
                Dennis
                • John F.
                  • March 23, 2008
                  • 2424
                  Sorry! www.rarecorvettes.com
                  John
                  • Mike P.
                    • December 28, 2010
                    • 27
                    Thanks, I read and copied the article. This should help guide me to correcting the problem.
