Re: '61 Fuelie Suddenly Running Rough
HI Larry, I got in on this conversation late.
First of all I recognize the modification on your FI unit. Appears to be typical of John's FI in CA. The altered fuel meter cover that has the bypass line installed is one clue. The line runs under the FI unit to the spider and a small Skinner valve. He taps into the top of the spider with an elbow, etc.
Although not original and not my forte it does typically work OK. Takes a lot of bucks though to undo this modification. New spider, maybe a new fuel meter cover although the hole could be plugged, cranking signal valve, vacuum line and of course the hard to find original Brass T fitting for atop the fuel meter cover. But this is not the issue. This is not what your complaint is.
57 to 61 FI's do NOT have a choke as Jim mentioned. A real deal choke didn't come out until the '62's and was used from 62 to 65.
The earlier units have a cold enrichment. Read all about this in "Corvette Servicing Guide" St12 Manual. Info in the theory section. Great theory for all interested in FI's to read and learn.
Sound like you could have picked up a little bit of dirt or varnish.
When the car is hot put your finger on the "choke" cover Larry. If you burnt your finger then it's working. If not then it died.
But with your nice photos it appears to be working. Look in the theory section again of the manual. You may have a sticking power boost pin or even the smaller enrichment pin. The power boost pin is the fat pin. This would cause the unit to run fat/rich.
A vacuum leak would cause idle flucation. A vacuum leak would make the FI hunt/search for a signal thereby causing erratic idle. Your main diaphragm cover could be warped, that 90 degree fitting could be loose, the rubber hoses could have cracks, the 90 degree rubber hose under the air meter could be loose or cracked. The main diaphragm might have issues. Your small diaphragm which is the enrichment diaphragm appears to be OK from the photos.
Hot ethanol is the pits on our FI's you know. Try some better fuel like 100LL. Open the hood when the engine is hot and see if that helps.
Forgot some elementary info. Spill valve could be sticking. Whew!!!
If you have the original spill valve that Bill Thomas nicknamed the good guy then that could be the problem. I calll those POC valves the bad guy. Replace it with the thumb tack style spill valve. Good luck, John
P.S. Try a little fuel injection cleaner in the gas.
Ethanol is probably boiling away. Your fuel line going from the fuel filter to the engine fuel pump may be too close to the valve cover. Attend to this if it is.
