Need A Little Help About My Vette It Is A 1967 427 400 Hp With Facory Air This Car Does Not Have The Air Vent In The Middle Of The Dash It Is A Facory Air Car Early Production Could This Be Facory Or Has Someone Chaged The Dash Thanks Steve James
1967 Vette 427 400 Hp With Factory
- Top
Bill Lacy
1998 Indy Pacecar- Top
Re: 1967 Vette 427 400 Hp With Factory
Steve:
I do not believe that this is a factory mistake. I have never seen this before on an original car......early or late production should make no difference. The 1966 and 1967 factory AC dashes are essentially the same, so this would eliminate a year-year changeover issue.
I don't know what the right answer is, but there are many possibilities. You just need to carefully check the remainder of the car, all AC system components, and AC special construction features to try and arrive at the answer to your question.
Larry- Top
Possibly some good news and bad news. The car is listed in the C2 registry as a Canadian export car, so there is documentation available. The bad news is that it's listed as a 390 hp without air. Good luck.
http://www.c2registry.org/index.php?...=1106&uid=9890- Top
much more likely someone added air to a non air car. Especially if someone already put it in the registry as a non air car. Adding a tri power is easy enough. Post a copy of the window sticker. There are some telltale signs many can comment on.- Top
Hi, Steve, and welcome to the technical discussion board! I see you're fairly new.
Sounds like a great car no matter how this odd dash issue turns out.
Do you have the tank sticker......?
RidgeGood carburetion is fuelish hot air . . .- Top
Agreed.........but the engine build stamp is different between the two engine configurations.
390 HP suffix would be IL (4-spd) or IQ (auto)
400 HP suffix would be JC (4-spd) or JD (auto)
Larry- Top
Steve,
Pics of the dash rivets and The engine pad as well as the tri power set up will assist the members here with what you have.
What is the status of the car - restored, driver, resto mod?
Did the previous owner drop the gas tank - take off the tank sticker? Any mentions of that? Those can be "produced too".
Have you purchased the NCRS shipping report? That will confirm the read original dealer and if a Canadian car, I understand all the OE details are available.
For better or worse...its still a great car.- Top
From the C2 registry it shows TI, can a 390 car get TI???
The other ting to note is that it is produced 9-15-66... and yet it was imported to Canada Feb 67?
That would suggest the original dealer was not Canada, seems a real long time to cross the border.- Top
Ron,From the C2 registry it shows TI, can a 390 car get TI???
I believe that TI was available with all engines, mandatory with some.
Joe- Top
