hello on my fathers 67 427 with a may casting of the 351 block, the rear journal of the cam and the original cam barrings have the grove like the 65-66 BBs. the original distrbutor with the semi circle grove. it was my understanding only the 65-66 BBs had all this. there is a casting number or part number stamped into the cam of 3883044. this came out of a 427/390
67 427 oiling questions
Re: 67 427 oiling questions
Keith -hello on my fathers 67 427 with a may casting of the 351 block, the rear journal of the cam and the original cam barrings have the grove like the 65-66 BBs. the original distrbutor with the semi circle grove. it was my understanding only the 65-66 BBs had all this. there is a casting number or part number stamped into the cam of 3883044. this came out of a 427/390
I think you'll find that the cam casting number is 3883944, which was the one-year-only '66 390hp cam with the groove in the rear journal. Can't imagine why a 351 block would have a 3-hole internally-grooved rear cam bearing in it - does the rear cam bearing bore in the block have a groove machined in it?- Top
Keith -
Then the 351 block is machined as expected, for the '67-up one-hole non-grooved rear cam bearing; but it has the earlier 3-hole grooved bearing in it and the grooved '66 cam? Weird...- Top
The number on the pistons may either be the casting number or the finish machined number.
Service pistons were only sold with pins, so the part number of the service assembly of piston and pin is what you buy OTC.
The same applies to camshafts. The molded part number is the finished part number of the camshaft, but service camshafts were only sold as an assembly of finished camshaft and indexing pin, which had a different part number, often sequential with the finished camshaft part number, but not always.
The Chevrolet drawings corresponding to the service camshaft part number is just a simple side view assembly drawing of the pin and front of the camshaft. All the detailed dimensions for the camshaft, including the as cast dimensions, are on the drawing number molded into the core.
Duke- Top
Keith-----
Where are the numbers on the camshaft? Are they raised numbers between the lobes or are they stamped on the end of the cam?In Appreciation of John Hinckley- Top
with a grooved cam and grooved block you should have had plenty of oil to the valve train plus a big internal oil leak around the rear cam bearing. like i posted before i have seen grooved cams come out of newer L-88 short blocks and over the counter engines bought for race cars. was this engine ever apart before you got it as some shop could have installed the wrong parts??- Top
Clem -- here's an NOS eBay cam described as L88, with grooved rear journal, and part # 3994094. This number is way newer than the parts books I have -- must be post 1970. Listing also shows some good shots of stampings on the ends.
- Top
the 094 cam i believe was for FI and tunnel ram applications. i never saw a BBC cam without being stamped on the rear cam bearing journal.Clem -- here's an NOS eBay cam described as L88, with grooved rear journal, and part # 3994094. This number is way newer than the parts books I have -- must be post 1970. Listing also shows some good shots of stampings on the ends.
http://cgi.ebay.com/ebaymotors/1967-...item4cfa728e89- Top
