1960 Powerglide Question - NCRS Discussion Boards
  • Joe M.
    • April 30, 1990
    • 1342
    After two and 1/2 months, it was time to add ATF to the PG and see what happened. I did not drain the torque converter. The 1961 Passenger Car Manual said to add 3.5 quarts of ATF, run the engine at 800-1,000 RPM until PG was warmed up and check the dipstick. There was nothing on the dipstick so I added two more quarts and there is still nothing on the dipstick. I have added a total of 6 quarts and when it is completely drained it holds 10.5 quarts.
    I don't know what to do now.
    Keep adding ATF until it shows full on the dipstick?
    or
    Drive it a few miles and check the dipstick periodically?
  • Domenic T.
    • January 29, 2010
    • 2452
    Re: 1960 Powerglide Question
    or
    Joe,
    How much ATF did you drain?
    Usually the trans won't work a few Qts low.
    10.5 Is almost max that the trans holds.
    I don't remember if the old cast iron had a overflow as the newer transmissions do but untill they got within a few Qts of full the car would not move.
    DOM
    • Joe M.
      • April 30, 1990
      • 1342
      I don't know how much I drained since a lot of it went on the garage floor. My aim was bad on placing the drain bucket in the correct spot. Then when I removed a side cover, more would pour out, usually on me; then the reverse servo piston popped out and more ATF poured on me.
      I am going to double check to be sure that I inserted the dipstick tube deep enough into the side cover when I removed it and replaced the o-ring. Tonight, I pulled the dipstick and there was an inch of fluid at the bottom. I never drove the car after starting it on Saturday.
      I will start it on Monday, warm up the PG and check the dipstick again; maybe then take it out for a few miles. I am in uncharted territory here (over my head).
      • Domenic T.
        • January 29, 2010
        • 2452
        Joe,
        At one time we all got a bath like that
        Those that didn't will some day.
        DOM
        • Joe M.
          • April 30, 1990
          • 1342
          Update: I added an additional 2 quarts for a total of 8 quarts and the ATF level is even with the Full mark. I did not drive it but shifted it back and forth into reverse and drive. Shift into reverse is smooth, but shift into Drive is hard. I believe it is safe to drive now.
          • Dan P.
            • December 1, 1990
            • 683
            Even thouigh you did not drain the converter the Powerglides are know for the converter drain back.So the converter may have drain back some fluid. There is a check valve in the valve body for this. So you need to add fluid till it shows full.
