'67 seat back hinge screws: special tool - NCRS Discussion Boards
  • Gary W.
    • November 20, 2006
    • 47
    gents, must admit to getting fed-up with these screws constantly working loose.....yes, fitted correctly with correct 'spacer washer' and even adding a few drops of Locktite.
    Anyhow, after nearly giving my passenger whiplash when his inboard seat-back hinge popped out under full acceleration in the L71, I decided something had to be done.
    So after pulling the passenger seal out and re-installing the hinge screw I made the "1967 Seat-Back Hinge Screw Tightening Special Tool" pictured below. This is so I can routinely tighten the screws BEFORE they pop-out - this procedure is now added to my routine maintenance schedule.
    Of course, if any of you fine gents have a better (permanent) solution then I'm all ears?
    Cheers, Gary (Perth, Austaria)
  • Gary W.
    • November 20, 2006
    • 47
    Re: '67 seat back hinge screws: special tool
    wow, looks like my '67 is a super-rare 1-of-1 example as no-one else seems to have this problem......does that make it more valuable?
    • Jack P.
      • March 19, 2009
      • 1135
      You may try Loctite , use the blue kind, it will hold the screw , but will come out when you want it to, Red is the more permanent type.
      I may have it reversed, but you get the idea, see the labels
      I used it all the time on my model helicopters, lots of vibration, so a need to secure bolts and screws
      Jack
      • Rich P.
        • January 12, 2009
        • 1361
        Original screws have a slot cut in the threads and plastic inserted to lock them in place.
        Rich
        • Donald O.
          • May 31, 1990
          • 1593
          I guess I'm unlucky.....mine stay tight without using any locktite when torqued to spec.
          DonO
          • Gary W.
            • November 20, 2006
            • 47
            Rich
            Rich - any idea where I can source 'original stryle screws'? The ones I've got are from LICS but don't have the slots/plastic insert.
            cheers,
            Gary.
            P.S. thanks Jack, but I've tried loctite to no avail
