Ls Motor Into A 1958 To 62 - NCRS Discussion Boards
  • Paul S.
    • June 30, 1982
    • 359
    Has Anyone Put An "LS" Motor Into A Solid Axle? ( With A Stock Frame) Problems??
    • 43290
    Re: Ls Motor Into A 1958 To 62
    Paul------
    I've seen LS-series engine conversions for C1, C2, and C3 Corvettes in several of the automotive magazines. I don't recall which ones or which issues. However, as I recall, the conversions required a lot of modifications and special parts in every case.
    The reason I don't remember too much about it is that I was not very interested. As good as an LS-series engine might be, I'd never consider retrofitting one to any Corvette. To me, it just does not make any sense. I consider it more of an exercise than useful.
    • Tom H.
      • December 1, 1993
      • 3440
      Hey Paul. I don't know anything about these guys, but I bet they can answer your questions !!
      Tom Hendricks
      Proud Member NCRS #23758
      NCM Founding Member # 1143
      • Paul S.
        • June 30, 1982
        • 359
        Thanks For Your Help
        • Clem Z.
          • January 1, 2006
          • 9427
          there are aftermarket blocks out there that use the LS series heads and intake but maintain the original small block chevy externals so it will bolt right into a older chevy.
          • Clem Z.
            • January 1, 2006
            • 9427
            here you go !! http://www.enginebuildermag.com/Arti...ies_heads.aspx
            • Dale M.
              • December 27, 2007
              • 386
              I am aware that the "Restoration Station" has experience putting LS Motors into earlier model corvettes (I believe it was a '62 that I saw). They are great at painting restoring vettes. The contact is Jeff Bernhardt The Restoration Station 250 Hiawatha Trail Springboro, OH. 45066 ( 937 ) 743-3007
              • Bruce B.
                • May 31, 1996
                • 2930
                Paul,
                Try a GM Ramjet 350.
                It bolts in, self contained ECU, lots of power and great gas mileage.
                It does require a small modification to the center hood reinforcement.
                Just add 12 volts and fuel.
                I put one in a 62 a while back.
                • Roger W.
                  • January 29, 2008
                  • 572
                  I was at the Walmart Library the other day looking at a Super Chevy Magazine. One of the writers said that there are motor mounts available to adapt LS mounts to SB chevy mounts. There are weld on SB chevy side mounts for C1s available from various vendors. Corvette Central has them. You would still need to figure out a trans mount.
                  I would think that it would be just a matter of time before somebody came up with a complete LS coversion kit for C1s.
