1957 wiper nozzels dilemma - NCRS Discussion Boards
  • Gary J.
    • April 1, 1980
    • 1246
    I am helping a friend with a 1957 May built car in which he has a dilemma about. When stripping the car he found the car was drilled for windshield washer nozzels. Underneath the cowl was some black cloth tape which looks like it was factory installed.
    Here are some other clues:
    1. There are no indention on the bottom side of the cowl for and evidence for a washer for the nozzels.
    2. There is not any holes drilled in the floor board for the washer pump.
    3. There is not any holes drilled in the inner fender for the washer resovior bracket.
    So how to repair, install the washer nozzels, or repair the cowl as if they were not installed. If repairing the cowl what would be the beat way to fix as to be not evident that the nozzels were install.
    Could this be a factory error. When were the cars drilled for the nozzels.?
    Thanks!
  • Mike M.
    • May 31, 1974
    • 8408
    Re: 1957 wiper nozzels dilemma
    was the front clip ever replaced? if not, then i'd fill the two holes in the top surround where the nozzels were located. be sure to take measures to hide the evidence of holes on the underside of the top surround .mike
    • Gary J.
      • April 1, 1980
      • 1246
      Mike, the front clip has never been replaced. The car has never been hit. Even the ledge around the engine compartment is in great shape and needs little repair.
