67 Starburst removal - NCRS Discussion Boards
  • Rick M.
    • July 31, 1982
    • 39
    Can you give me some hints on the best way to remove the Starburst Caps on the 67 Bolt Ons without bunging up the cap? The screwdriver route puts a small nick in the cap by the access hole. There has got to be a better tool for removing these caps.
    Thanks, Rick
  • Larry M.
    • January 1, 1992
    • 2701
    Re: 67 Starburst removal
    Thanks, Rick
    Rick:
    This is what you need. http://www.thetoolwarehouse.net/p-14...ools-3245.aspx
    They are made by several companies, KD is one. Available most auto parts stores, or order on-line.
    Works very well. It is what I use, and is recommended by many other 1967 owners.
    Larry
      Originally posted by Larry Mulder (20401)
      Rick:
      Larry
      Yup - that's exactly what I use on mine - just stick a rag behind it so you don't scratch the paint, and it pops the caps right off. The screwdriver method is hopeless.
      • Rick M.
        • July 31, 1982
        • 39
        Larry and John:
        Thanks for the great tip. I'll be going to the Tool Store!
        Rick
