65 Headlamp Assembly Removal - NCRS Discussion Boards
  • Mike W.
    • November 1, 1990
    • 71
    Help! We are painting a 65 coupe and lack one bolt on each headlamp housing to be able to remove it. Can't seem to get a wrench on the bolt head. Part of the assembly is in the way.
    Re: 65 Headlamp Assembly Removal
    If you remove the motors, you can rotate the buckets into position such that the three bolts on each side are accessible through the provided holes in the end walls of the buckets.
    • Jim D.
      • 2884
      You'll have to remove the "Y" stops as well.
      • Jimmy B.
        • July 31, 1980
        • 584
        don't use a wrench on the bolt head, a 1/4in. rachet drive with the correct bolt head size from inside the housing with a small extension if memory serves me correctly is required
