111156/111196 Distributor Parts - NCRS Discussion Boards
  • Bob S.
    • January 1, 2004
    • 182
    Hello,
    Now that I've run the 111156 distributors from my '66 and '67 L79's on my Sun Distributor machine, I see how far off the centrifical advance curves are....
    I'm looking for correct weights and springs to acheive the proper curves.
    I understand that Chevy distributors 1111483 and 1111490 both use the same weights (1881371) and springs (1951743) that the 1111194, 111156 and 1111196 distributors use.
    Does anyone know if there are other distributor p/n's (preferrably non-Corvette) using these same weights and springs?
    Any similar info concerning the mainshaft would also be useful. If I can't find any used distributors with the correct mainshaft, I'll be foreced to buy reproduction parts from the normal sources. (Both of my distributors now have the '153 stamped shaft/top cam that previous threads indicate is not correct.)
    Thanks in 'advance', for any help!
    Bob
    Last edited by Bob S.; September 24, 2011, 09:00 PM. Reason: To make title more accutate
  • David L.
    • July 31, 1980
    • 3310
    Re: 111156/111196 Distributor Parts
    The 1112002, 1111481, and 1111500 distributors also use the 1881371 weights but use different springs according to my Delco-Remy Service Parts Catalog.
    The 1111153 & 1111156 distributors use the 1923139 springs according to this same catalog.
    According to my 1967 Chevrolet Parts Catalog lists the 1923139 springs are listed for the following:
    66 ALL, CORVETTE w/P.G. (327)
    66 CORVETTE (A.I.R. w/Sp. H/Per.)(327)(exc. T. Ign.)
    The 1951743 springs are listed for the following:
    66 ALL, CORVETTE w/P.G. (327)(exc. A.I.R.)
    66-67 CORVETTE (327)(exc. T. Ign.)
    Dave
