Muncie Tune-up in Michigan - NCRS Discussion Boards
  • John G.
    • April 1, 1999
    • 50
    My '67 wide ratio Muncie is having a hard time getting into 2nd. I can finesse my way into 2nd, but other drivers (not naming names) have a real hard time. I suspect the synchonizer is worn. The gear box has never been touched as long as I've owner the car (1994).
    Any recomendations for Muncie rebuilders in S/E Michigan?
    I'm in Ann Arbor so that area would be preferable.
    John
  • Kenneth T.
    • March 23, 2008
    • 631
    Re: Muncie Tune-up in Michigan
    John,
    No offfence, but have you looked at the linkage adjustments. I have found loose nuts on the levers many times.
    Are you getting any gear grinding when shifting?
    Ken
      • April 1, 2000
      • 477
      Originally posted by Kenneth Tozzi (48795)
      John,
      Ken
      This is good advice based on personal experience with this same issue. It could end up being a trans problem, but with what you've described, I'd diagnose shifter linkage adjustment/repair/replacement. Especially if the shifter has not been serviced/adjusted in a while, and/or is the original, and/or has a fair amount of miles.
        John
        John -
        PM sent.
        • John G.
          • April 1, 1999
          • 50
          Hi Guys,
          I have thought about a linkage too. It definitely has a tendency to grind going into 2nd - especially when its cold.
          I spoke to the local dealer and they asked if I could shift into second with the car standing still - which I can with no problem. Based on that they felt that it was a gear problem and not a linkage issue.
          I am in no way an expert on transmissions. I did watch a video on rebuilding a Muncie - which was right before I decided to ask for references on rebuilders.
          I am willing to look at the linkage - any suggestions on what to look for?
          John
          • Kenneth T.
            • March 23, 2008
            • 631
            John,
            Rather than take up space here on a topic that has been well developed, just use the search function for "Muncie Linkage" You will get a lot of good advice. Good luck, I always look for the easy stuff first. I hope it is only a loose bolt.
            Ken
            • John G.
              • April 1, 1999
              • 50
              Thanks Ken. That's good advice.
