1966 Battery small block non air car - NCRS Discussion Boards
  • Rick E.
    • July 7, 2011
    • 3
    a couple of questions regarding a battery.
    Where is the best place to get an acid filled delco "original" battery?
    What do people soak the felt that goes over the positive post in?
    Battery tender....is the a good tender out there that hooks up to "spring ring" cables....the ones I see in catalogs that have the knob on top to twist on and off don't seem to be compatable unless I'm missing something
    thank you,
    Rick
    Re: 1966 Battery small block non air car
    thank you,
    Rick
    Rick -
    The felt washer was saturated with hypoid gear lube.
    By "battery tender", do you mean a battery disconnect switch? There are two versions for top-terminal batteries - one has the "green knob", and the other is a knife-type switch; both work fine with spring-ring cable ends. Paragon (and others) have them.
    • Joe R.
      • May 31, 2006
      • 1822
      thank you,
      Rick
      Rick,
      You can get the battery disconnect at NAPA, I prefer the knife type because it gives a visual indication. Here's what I think is the best battery tender, since it desulfates and charges:
      http://www.batteryminders.com/batter...nditio-p-16134.
      By the way, you can get it cheaper elsewhere.
      Joe
