1958 Gm Parts Book - NCRS Discussion Boards
1958 Gm Parts Book
  • Ronald R.
    • May 31, 1989
    • 670
    1958 Gm Parts Book
    Does anyone have one, i have a 72 and all the parts I am looking for were discontinued at that time. Nolan Adams page 289 shows the rod #3750537, I need deminsions so I can build one, this is the rod from the kick down bracket for a 250 HP FI PG car to the throttle linkage. He also shows the rod and bracket ( I think mine is right) for the FI car to be #3752490 and #3751674 for the 2x4 PG cars, any help is appreciated. thanks Ronnie
  • Cecil L.
    • May 31, 1980
    • 449
    Re: 1958 Gm Parts Book
    3750537 is listed under Group 4.019 Rod-Spring-Washer-Clevis. Gearshift Control, as:
    58 PASS, CORV. (F.I.) w/A.T. throttle valve cross shaft
    No dimensions given.
    • Ronald R.
      • May 31, 1989
      • 670
      any one know where to get demensions?
      thanks RDR
      • Scott S.
        • September 11, 2009
        • 1961
        thanks RDR
        Ronnie,
        The 1963 P&A (oldest I have) says:
        58 . . . PASS, CORVETTE (A.T. w/F.I.) . . . . . . . throttle valve cross shaft (8 dev. length) . . . 3750537
        The 1969 P&A shows that this part number was removed from service 12-68.
        • Scott S.
          • 1961
          58 . . . PASS., CORVETTE (F.I. w/T.G.) . . . . . w/bracket . . . . . . . . . . . . 3752490
          Group 4.040
          58-62 PASS., CORVETTE w/A.T. (8 cyl.) (exc. F.I., 327) . . . . SHAFT, w/brkt., throttle valve cross . . . . . . . . . . 3751674
            • 43219
            Ronnie-----
            All I can tell you is that the GM #3750537 was discontinued without supercession in December, 1968.
            • Ronald R.
              • May 31, 1989
              • 670
              From what I can determine the 4 bbl rod is identical only longer. The 8" mentioned above looks rto be about right. I guess if I cut the 4 BBL rod down and rethread only me and my hairdresser would know! thanks guys
              Ronnie
              • Ronald R.
                • May 31, 1989
                • 670
                Does anyone have demensions for these tworod and brackets? I think I have the correct one but not sure
                thanks RDR
                Group 4.040
                • Cecil L.
                  • May 31, 1980
                  • 449
                  I'll check my 59 Special Parts catalog and see if it shows any additional info. First, I have to find it.
