I am considering changing current paint color to original cascade green. I like the idea of soda blasting. I would appreciate any advice. Thanks in advance for any suggestions.
C1 color change
Re: C1 color change
I have to agree on that, I will be repainting our Honduras maroon/white the original color, but did let a black one go through my mind. There are good preparation/painting tips in the 1958-60 Corvette Restoration handbook.
Phil- Top
Re: C1 color change
I did not make my posting very clear. My 57 is currently black with a silver cove. It think it was originaly was cascade green. In the engine compartment, I found cascade about 6" or soon from the top on the inner fender in the engine comparment and paint chips thru out the body. The cascade green was on top of red primer. From that, I beleive that it must be the original color. Mike, I am having this service performed at their shop under my supervistion. Thanks for the heads up on aggression. Is there a better way? My project is going to be a frame up. Wish I could handle a frame off!!! Thanks for your input. Any other tips??- Top
Re: C1 color change
Jerry:
I apologize for jumping to such a quick conclusion. Bravo for returning the car to original manufactured state. I am glad mike chimed in the soda being around for ever, I was going to soda blast my '65, because I thought if i washed afterword it would remove al traces. I had a suburban plastic mead stripped a number or years ago and the plastic was everywhere including the paint.
Good luck.- Top
Re: C1 color change
Is there any chemicals involved?
No chemicals at all just water. You have to be at the correct angle. The paint came off in big chips. I only had a small area that ruffed up the glass and that was on a repair area.
If you want more pictures, just email me your address.- Top
Re: C1 color change
Here are videos of my power washing the paint off my Corvette. LOL
It worked!
http://www.youtube.com/watch?v=FGDhi6ZjpYo
http://www.youtube.com/watch?v=KptKKcqnqIc- Top
Re: C1 color change
Jerry we have had several cars media blasted with no problems. The same with soda. It is all in the operator, not the materials. I watched as they soda blasted a car. He was stripping the paint one layer at a time. I asked if he could leave the primer, said no problem, proceeded to strip one quarter and leave the primer. Cleaned the car up with compressed air and then water.Dick Whittington- Top
Re: C1 color change
Thank you Dick, I will watch em like a hawk and see previous work. JerryJerry we have had several cars media blasted with no problems. The same with soda. It is all in the operator, not the materials. I watched as they soda blasted a car. He was stripping the paint one layer at a time. I asked if he could leave the primer, said no problem, proceeded to strip one quarter and leave the primer. Cleaned the car up with compressed air and then water.- Top
