1967 directional signal - NCRS Discussion Boards
  • Robert B.
    • December 1, 2005
    • 21
    How do you go about changing the dirictional signal arm on the steering column. Do you need special tools.
  • Domenic T.
    • January 29, 2010
    • 2452
    Re: 1967 directional signal
    Robert,
    Yes you do but it is a simple one. It is a steering wheel puller.
    You can make one or rent one.
    Your manual will give you instructions but don't forget to disconnect the battery so you don't blow the horn, also make sure you mark the position it was in before you remove it.
    DOM
    • Gerard F.
      • June 30, 2004
      • 3806
      Robert,
      Changing the signal switch arm is a snap once you pull the steering wheel and housing off. You don't need to remove the wheel from the housing, it pulls off as one piece.
      But if you are changing the signal switch itself, take a look at this thread in the archives. Jim Shea has a great article on the 67-68 steering column on a post in this thread:
      https://www.forums.ncrs.org/showthre...witch&uid=2831
      Jerry Fuccillo
