This Idler arm has the correct casting number (3779185) and the straight lever (not offset, as the idler arm with same casting number for trucks). The rubber boot has the "KF" logo, same as my original. It has the GM sticker with the 3779184 part number, but it's torn, so the sticker could have come from anywhere.
All of the correct markings are present, except the "B" that is stamped into the flat bottom surface on the end of my original where the lever attaches. It has grease filling up one of the bolt holes (just seemed an odd place for grease), and generally grease all over, same color (dark brown) and consistency grease is under the boot as well. Grease looks old, with organic matter (hair, seeds, fragments of leaves) mixed in with the grease in places, like it was stored on the floor in the back of a woodshed.
Is there a way to tell whether this is really NOS, or just used? My original has grooves in the bolt holes from the bolt threads, this one does not. It probably wouldn't be difficult to hone the bolt holes smooth, but these aren't smooth either, they have a slightly rough swirling type of machine marking inside the bolt holes.
The other question, is there a way to determine whether the idler arm is in good working order, without installing and testing it on a car?
