Technical Service Bulletins Source 1990 - Present - NCRS Discussion Boards
  • Steven B.
    • June 30, 1982
    • 4010
    Many of you may know that NHTSA has copies of some TSB's by manufacturer, I bellieve back to 1990.
    www-odi.nhtsa.dot.gov/cars/problems/tsb/tsbsearch.cfm
    From the site:
    Search for Service Bulletins
    The Technical Service Bulletins Search Engine will allow searches of summaries of the Manufacturers' Technical Service Bulletins by single year, make and model. An optional item of Vehicle Component may be selected to help narrow the focus of the search. (The data does not contain all the service bulletins generated by a manufacturer. Bulletins for safety recalls in general are not included, and also bulletins which may not pertain to a defect may not be included.)
    If known, enter the NHTSA Item Number(s) in the text box on the left below. Otherwise select Vehicle, Equipment, Child Restraint or Tires from the list on the right below. Then use the appropriate Search button to continue.
    Select
    Type
    Model Year
    Make
    Model
    Component
    Quick Search
    NHTSA Item Number:
    (e.g. 654321)
    Or Select the TYPE of Search
    Vehicle Equipment Child Restraint Tires
    Please Note: Documents which are summarized on database searches, may be ordered from NHTSA Technical Information Services. Fees are involved in providing these documents. The following link describes TIS Fees. Also described is the TIS Reading Room, where visitors can view and/or copy documents and files.
    Steve
