'70 Brake Calipers - NCRS Discussion Boards
'70 Brake Calipers
  • Kenn S.
    • September 10, 2009
    • 173
    '70 Brake Calipers
    My car, a "barn find" type of thing, is missing two calipers (from pass side, both front/rear). I can't get to the driver's side as the car doesn't run and is parked, for the moment, against a wall, too close to jack up (but not too close to squeeze past). If I could, I'd read the casting numbers from those calipers, but they may be incorrect anyway. Don't know yet.
    So, I'm rooting around for the proper calipers. My research so far tells me I need the "second design" calipers with the following casting numbers:
    Front inner: 5452270
    Front outer: 5452273
    Rear inner: 5452281
    Rear outer: 5452284
    I didn't find any from another car on the 'Net, but I did find SSBC sells refurb'd units, and possibly with these very casting numbers (if I request them, which I would, and assuming they have any).
    Anyone know if these numbers are correct, and anyone ever purchase calipers from a vendor and have them judged as correct?
    -Kenn
    1970 LS-5
    1970 350/300
    1980 L-48
    2004 LS-1
    • 43247
    Re: '70 Brake Calipers
    Rear inner: 5452281
    Rear outer: 5452284
    Kenn-----
    Those are the correct numbers for a 1970.
      • 11668
      Almost any rebuilder can get you the correct number calipers, and Lonestar Caliper even makes them brand new, allegedly from the original molds.
      • R N.
        • May 31, 2002
        • 640
        Ken,
        I purchased mine from Brian at Bair's Corvette in PA. They are just GREAT people to deal with. I've purchase 3-other sets from them over the years and always consistant.
        Contact Brian at 814-683-4223 or 1-800-421-9644
        • Kenn S.
          • 173
          Awesome. Thanks! I'll make some calls...
          -Kenn
          1970 LS-5
          1970 350/300
          1980 L-48
          2004 LS-1
