I hope someone can help me out. My LT-1 w/AC blower fan quit on me in the high speed or fourth and last notch to the right. All other speeds work fine. In one of the threads I found that a fuse located close to the alternater on a red wire could be the problem. I checked it and it is not blown. In the 1972 service manual on page 1A-52 @ the lower right under FUSES it says a second fuse for high speed is located between the horn relay and AC relay. Where is this fuse located or is it the same fuse I already checked???
