Re: damaged differential advice
Fourth picture from the bottom... note that there is a section change at this point where the failure occurred. Most of the cross section has a relatively smooth surface, but somewhat less than a quarter of the area has a rough surface. This is a classic fatigue failure resulting from propagation of a crack.
The section change creates a stress concentration at the corner. Any small surface flaw in this area can result in a crack that will grow across the section. The slight relative movement of the two surfaces on either side of the crack from service stress "polishes" it. Then, when the remaining section is small, normal driving stress will cause the UTS to be exceeded resulting in a final failure and rough surface in the area of the final sudden failure.
This is the same thing that happened to my SWC at 30K miles and why I recommend that any used R & P should be Magnaflux inspected with particular attention to the section change. Any evidence of a crack at this point renders the R & P unsuitable for further service.
At the time my drive pinion failed in 1965 I was a ME sophomore at the U. of Washington and was taking the required materials science class. I took the broken drive pinion to class and with the help of the prof we analyzed the failure.
