'69 under-the-hood order of assembly? - NCRS Discussion Boards
  • G A.
    • February 18, 2010
    • 229
    Regarding the firewall accessories; vacuum hoses, vacuum relay, wiper door actuator, wiring, wiper motor etc, which of these was installed first/second and so on?
    Also, is there a publication that documents the building order of the entire car that comes with good recommendation and plenty of photos?
    Dan
  • David H.
    • June 30, 2001
    • 1559
    Re: '69 under-the-hood order of assembly?
    Dan
    John Hinckley gave an excellent presentation on the Assembly Sequence at the National this year. You can download it from the Michigan NCRS site. Hope that helps
    • G A.
      • February 18, 2010
      • 229
      Got it. HolySchmoly! Thanks David, that looks very interesting. But it doesn't cover 1969's!!
      Dan
      • David H.
        • June 30, 2001
        • 1559
        Dan,
        Perhaps John H. will chime in, but I believe the basic process was pretty much the same for all the St. Louis years.
        Another interesting book is: "BIRTHPLACE OF LEGENDS, The Story of Corvette Production at the St. Louis Assembly Plant - 1953-1981 by Peter J. Licastro, 1993, ISBN 0-9630555-8-5. Many photos and description of the assembly process.
        Also, some photos of Corvette assembly 1980 (1981 production) on the Digital Corvettes site may be useful:
        • Russ S.
          • April 30, 1982
          • 2163
          John, This is so awesome!! It really made me wish I had been there at the time. Great job!!
            Russ -
            Thanks - I thought I'd better put that 27-page .pdf together with the complete, detailed assembly sequence all in one place before the information was "lost"; the other three PowerPoint files illustrate it in less detail, but with lots of photos. The PowerPoint files are what I presented at the National Convention in Novi.
            • G A.
              • February 18, 2010
              • 229
              Awaiting delivery of the "Birthplace of Legends". Meanwhile somebody must know the answer to my question?
              What was the order of assembly of the components that adorn the firewall of a '69?
              Was the wiper motor installed before or after the vacuum hoses and control valves?
              When was the engine/starter wire harness installed, before or after vacuum lines/valves, before or after wiper motor?
              Dan
              • Terry B.
                • August 31, 1999
                • 607
                Hi Dan,
                Per the '68/'69 TJM the wiring harness was the first component installed in the clips mounted on the inner fender, it should be the lowest in the clips. The vacuum hoses were bundled together using a black cloth like tape as ties and not a wrap. If transistor ignition is present, a third harness will run from the area of the distributor and coil along the driver's fender.
                I hope this helps.
                Terry Buchanan
                Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
                Corvettes Owned:
                1977 Coupe
                1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
                2003 Electron Blue Coupe
                2019 Torch Red Grand Sport Coupe
                • Mark S.
                  • April 25, 2019
                  • 94
                  Cant seem to get to that since i am not a Local member but a FL member. Thanks, Mark
                  • Bill B.
                    • August 1, 2016
                    • 305
                    Mark,
                    On the Michigan home page, click the "Home+" button on the top left, then "Downloads" in the submenu. That should work.
                    Bill Bertelli
                    Northeast and Carolinas Chapters Member
                    '70 Resto Mod LT-1 w/ partial '70 ZR-1 drivetrain
                    • Mark S.
                      • April 25, 2019
                      • 94
                      thanks....got them
