What finish is the bracket that holds the hinge to the underside of the hood? I believe it has a zinc finish. Am I correct?
1972 hood hinge bracket
Re: 1972 hood hinge bracket
Kevin, Thanks for the picture. As I thought the hood support assembly is natural (cadium ?) finish.
Could you please let me know it the "hood hinge assemblies" (left and right) have a natural (cadium?) finish or are they painted.
Your help is and has been appreciated.Last edited by Jerome P.; September 28, 2011, 08:43 PM.- Top
Jerome
Here is a photo from ebay and if you need here is the ebay number 370519890653. I would call it a flat Cad plating not a bright zinc.
Hope this helps
Paul 18046Attached Files- Top
There have been some excellent photos posted on here in the past. SEARCH is your friend.Terry- Top
I usually think a bit "whiter" for cad.Vice-Chairman (West), Michigan Chapter NCRS
Jerome,
You need all three colors - cad plating, then body color, then blackout.
Like below.
Tory1975 Convertible
L-48, 4-spd, FE7, radio delete
Original owner
NCRS Top Flight Regional 2011, 2013
Dallas, TX- Top
