1957 Windshield Wipers - NCRS Discussion Boards
  • Roger K.
    Infrequent User
    • November 17, 2008
    • 6
    The windshield wipers start well but stop and then move only about 3 inches about every 20 seconds until they complete their cycle.
    Wipers have not been used for a long time.
    Any suggestions?
  • Adam S.
    • July 30, 2008
    • 167
    Re: 1957 Windshield Wipers
    Hi Roger, Remove ele. motor, Check motor pulled away from mount plate & see if drive output on motor moves back & forth with power applied to it for some time, then apply some resistance to it & see if it slips internally. Check to make sure both wiper clutches on transmissions are set properly, sounds like your motor is loose from its mount or gear box stripped
