Antifreeze Recommendation - NCRS Discussion Boards
  • Karl K.
    • November 17, 2008
    • 92
    I Am Going To Be Draining My Cooling System On My 65 327, Any Recomendations On What Brand Or Type Of Coolant I Should Refill It With?
    Karl
  • Michael D.
    • June 30, 1996
    • 536
    Re: Antifreeze Recommendation
    What's in it now?
    • Paul H.
      • September 30, 2000
      • 688
      I use the "green stuff" and mix it 50/50 with distilled water. In Mass I buy the store brand at Car Quest. Comes in a black container. Not sure in your area.
      • Karl K.
        • November 17, 2008
        • 92
        Its The Green Coolant
        • Michael J.
          • January 27, 2009
          • 7154
          Zerex G-05 is the only choice for an old car. It is an HOAT anti-freeze that greatly reduces any deposit buildups.
          • Karl K.
            • November 17, 2008
            • 92
            What color is the Zerex G-05?
            • Michael J.
              • January 27, 2009
              • 7154
              It is crystal clear, like water, and remember to only use distilled water in the radiator as well.
              • Karl K.
                • November 17, 2008
                • 92
                During Top Flight Judging would there be any deductions if its not green?
                I looked the my judging manual and didn't see anything.
                • Michael J.
                  • January 27, 2009
                  • 7154
                  I've had my cars judged many times for flight, they never take the radiator cap off and look at anything inside or any fluids for that matter.
                  • Karl K.
                    • November 17, 2008
                    • 92
                    Thanks for the help, I'll use the Zerex.
                    • Larry M.
                      • January 1, 1992
                      • 2701
                      Agree with the recommendation, but Zerex G-05 is a pale yellow or gold color...not water white. It is also available in other colors from various other sources. As an example, MOPAR labeled G-05 is pink.
                      Entire cooling system should be drained and flushed before switching from "green" to G-05. Probably not mandatory, but highly recommended (by me and many others).
                      Distilled water is also recommended for mixing, unless you buy the pre-mixed 50/50 version.
                      Larry
                      FWIW: This topic has been EXTENSIVELY discussed before, and all this info is available in the archives if you do a search.
                      • Michael J.
                        • January 27, 2009
                        • 7154
                        Well, the jugs I have are clear, no color at all, unless you look through a thick stream, very, very pale yellow. On the ground, clear as water.
                        • Larry M.
                          • January 1, 1992
                          • 2701
                          Well, the jugs I have are clear, no color at all.
                          Premixed 50/50 version?? The purified water used in this mix will dilute down the color significantly.
                          See page 2 of this Zerex G-05 specification under "color": http://www.valvoline.com/pdf/zerexg05.pdf. This spec sheet also has a lot of other good info on G-05.
                          Larry
                          • Michael J.
                            • January 27, 2009
                            • 7154
                            Larry
                            Of course, yes, nobody uses full strength anti-freeze for your coolant.
                            • Grant P.
                              • April 6, 2009
                              • 35
                              I just installed a Dewitt date coded radiator in my '65 L79 and used Zerex G05 mixing 50/50 with distilled water. No problems in 110 weather here in Arizona. Grant
