63 Rocker Moulding Screws 3830604 - NCRS Discussion Boards
  • Jeff Z.
    • February 1, 1994
    • 94
    Does anyone have pictures of lower rocker sill moulding screw 3830604 which was used both in 63/64. Screws attached rocker moulding to lower birdcage brackets. Archives show this as a SEMS screw however pics have been deleted. 66 AIM shows 9421851 which is a #8 or #10 Phillips pan head with a plain captured washer. Any dimensions of original 63 screws would be also helpful.
    Jeff
  • Jim B.
    • December 1, 2004
    • 54
    Re: 63 Rocker Moulding Screws 3830604
    Jeff--Here is a set of what I believe are original screws. They include the two different SEMS headmarks. The dimension (eyeballing it) from the underside of the washer to the screw tip appears to be right at 5/8". Hope this helps.
    • Rich P.
      • January 12, 2009
      • 1361
      Jim,
      both those are original and the 2 style headmarkings I have seen.
