Please take a look at the 4 photos and let me know what you think. Here are the details of this pump that do not appear to be common to the original 4656.
1) The long flat bossed area opposite the pump arm is incorrect, should be one boss per screw
2) Two vent holes on one side of arm tower, should be one hole on each side of the arm tower
3) Lack of dipped out places on each side of the arm tower to make it easier to insert the bolt and/or socket.
4) There is a flat place where the arm tower transitions to the flared out part of the pump body; original had smooth transition
Photo #4 has me baffled. The flange where the 4656 is stamped looks original; no evidence of grinding, the parting line is intact across the flange and the 4656 is stamped across the parting line. Please share your opinions on this pump .
