62 - Dimpled dots staked on motor mount nuts? - NCRS Discussion Boards
  • Anthony P.
    • June 27, 2010
    • 485
    1962-
    In the JM, page 62, section 14, Motor Mounts, it states that "Nuts are 5/8" and have 2 dimpled "dots" staked 180 deg from each other on the outer flats of the nuts.
    Would someone please post a picture showing these dots?
    Thank again for the help,
    Tony
  • Dick W.
    • 10483
    Re: 62 - Dimpled dots staked on motor mount nuts?
    They are garden variety distorted thread locknuts. Nothing special about them. I am sure that you can google distorted thread locknuts and see a photo of them
    Dick Whittington
    • Anthony P.
      • June 27, 2010
      • 485
      Dick, my question is more on the dimpled dots. Can I just use a center punch to make the dots on the outer flats?
      Tony
      • Dick W.
        • 10483
        It is more than a pin punch mark Look at the photo
        Dick Whittington
        • Brad H.
          • August 12, 2007
          • 724
          Most corvette venders have these nuts.
          • Anthony P.
            • June 27, 2010
            • 485
            thanks Guys
            • Anthony P.
              • June 27, 2010
              • 485
              I found the nuts at paragon.. Thanks..
              • Gary C.
                Administrator
                • October 1, 1982
                • 17689
                Don't know for sure about '62 - but the '56-'57 dimpled lock nuts are 7/16x20 x 5/8" hex AF (across the flats). Last time I checked vendors were selling 11/16" AF nut.
                check fellow NCRS member Paul Mazut's website
                JMTCW,
                Gary
                NCRS Texas Chapter
                https://www.ncrstexas.org/
                • Dick W.
                  • 10483
                  Checked all the fastener warehouses that we have used in the past. Seems 11/16" hex is all that is available today
                  Dick Whittington
                  • Jerry C.
                    • November 1, 1995
                    • 741
                    Paul Mazut has them 413 243 3439
                    • Anthony P.
                      • June 27, 2010
                      • 485
                      I called him this morning.
                      Thanks for all of the info.
                      Tony
                      • Anthony P.
                        • June 27, 2010
                        • 485
                        Attached is a pic of the nuts with the dimples.
                        These nuts are 5/8" and have 2 dimpled "dots" staked 180 deg apart.
                        Thanks for the help.
                        Tony
                          Tony
                          Tony -
                          If you'll use your camera's "macro" feature (little flower symbol), close-ups will be in focus.
                          • Anthony P.
                            • June 27, 2010
                            • 485
                            Thanks for the Tip John.
                            Here is a much better pic. I used my "real" camera!!
                            Tony
                            • Gary B.
                              • September 30, 1987
                              • 305
                              What is the decision re the HEX dimples and the ROUND dimples?
