Stained nuts?! One red...the other blue?! - NCRS Discussion Boards
  • Tory S.
    • 146
    Often mentioned is that the two nuts attaching the brake lines to the master cylinder are often stained red and blue to distinguish thread size. Does anyone know which nut is red and which is blue? I'm working on a '75. My best guess from photos of my original cars is the forward nut is red and the aft nut blue, but if someone can truly clarify, it would be great.
    Tory
    1975 Convertible
    L-48, 4-spd, FE7, radio delete
    Original owner
    NCRS Top Flight Regional 2011, 2013
    Dallas, TX
  • Rich C.
    • January 1, 1994
    • 383
    Re: Stained nuts?! One red...the other blue?!
    Good question. There is a current post; 'LS-5 valve cover', with some engine bay shots that seem to confirm that.
    '73 LS-4 454 owned 21 1/2 years
    • Tory S.
      • 146
      Rich,
      Thanks. I looked at them. I'm curious to what you see as to which nut is which color. I guess I'm not seeing the confirmation.
      Thx,
      Tory
      1975 Convertible
      Original owner
      Dallas, TX
      • Stephen L.
        • May 31, 1984
        • 3162
        Red = forward
        Blue = rear
        • Tory S.
          • 146
          Stephen,
          Thanks. I agree. Attached is a photo of a '75 and, although it's tough to see, the front nut looks red-ish and the rear blue-ish. To add to this, I found Cardone rebuilt MC use colored palstic plugs which further support the color scheme.
          Tory
          1975 Convertible
          Original owner
          Dallas, TX
          • Erich C.
            • January 31, 2007
            • 137
            I think this will help you. Check out page 4 on this website: http://www.momar.com/www/handyman/H/pdf/H15.pdf .
            It shows the oversize tube fittings along with it's color.
            Erich
