'62 door post help - NCRS Discussion Boards
'62 door post help
  • Todd D.
    • September 7, 2011
    • 9
    '62 door post help
    I just had both door posts rechromed and now prepping the body for paint. I noticed the two small studs (one threaded and one solid on the door posts have ripped the fiberglass apart on the door. It doesn't look like must material(glass) was around the studs to give much support. This must be common? Should I just reglass and drill a new hole? I suspect it will crack again under little stress. Anything I can do to fix this?
    Thanks for any help,
    Todd
