Installed new master cyl today and I have to much free play in pedal. Went to adjust rod and it was only threaded into clevis two turns. Master cyl dimensions match old unit and also match other threads I found on the subject. Pedal bumper is in place and the rod is 4.12 inches long and the clevis looks original. I estimate that I am about half inch short on the rod. Any ideas or will I have to make a new rod. Clevis was also installed in the upper hole. Manual brakes. Thanks Ed
Master cylinder push rod to short
Re: Master cylinder push rod to short
Ed, When looking at the master cylinder rear piston- do the pistons have the same distance the resting position new and old ? may have to pull rubber boot back if theres one present.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Ed, is there any way maybe the pedal support where attached to body may have some movement to bring pedal closer, I have never removed one so its just a question. at this point there may be something thats causing the extra space between cylinder and push rod.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Ed,
I suggest to try an aftermarket longer rod and see if you can make the correct adjustment. Be sure to leave a bit of clearance "free pedal" as the power brake unit needs full release to avoid dragging on brakes.
I do not recall if the 4.12 is the original rod length.- Top
Now that you mention the support for the pedal. This is a 66 that has a 67 steering column installed so maybe I need to look closer at the whole assy. mounting. The 4.12 dimension I have on the rod appears to be correct. I found a reference in the archives that confirmed this dimension. Thanks Ed- Top
The M/C push rod used on 63-66 Corvettes with standard brakes is GM # 3819077 in Gr. 4.658.
Enclosed is a sketch with dimensions.
DaveAttached Files- Top
Ed,
Here is a photo (on left) of the original 3819077 rod (meas. 4.17" long), 9419815 nut, 3819078 clevis, 3817879 pin, and 3817880 retainer from my 1966 Corvette. Refer to the 1966 AIM (UPC 5, sheet A2).
I also have similar assemblies from a 1963 & 1964 Chevrolet as well as a 1964 Chevy II where the rod and clevis are much longer. I also have a 3812970 rod from a 64 Corvair that measures 4.41" long. See photo on right.
Dave- Top
