'73-74 Fuel Pump Return Hose ? - NCRS Discussion Boards
  • Rich C.
    • January 1, 1994
    • 383
    All the vendors list it like this: '68-79 Fuel pump return hose- Except L-88, LT-1 and '73-74 454' Great I figured the L-88 and LT-1 didn't use one, but what about the LS-4? Any ideas on a replacement? I tried just buying the 'S' hose for the rest but it didn't fit.
    '73 LS-4 454
  • Rich C.
    • January 1, 1994
    • 383
    Re: '73-74 Fuel Pump Return Hose ?
    What's strange is the same fuel pump is used for 70-74 454's as well as the same return line. So what am I missing?
    1973 LS-4 454 owned 24 years
    1996 LT-4 CE coupe
    Sierra Nevada Celebration Ale-currently on tap!
      • 43248
      '73 LS-4 454
      Rich------
      All 1968-82 Corvettes used a fuel return hose except Holley carb applications (with one Holley carb exception to the rule----1971 LS-6 which DID use a fuel return hose). 1970-82 applications, except LT-1, had the fuel return hose running from the fuel pump to the fuel return line.
