Not to beat a dead horse with my fan questions, but I have a 3992095 fan with perfectly curved teeth. That is, the blades extend to the base of the tip, which is then curved (bent) to the front so that the tip of the tooth is 90 degrees to the fan blade face. All teeth have precisely the same curvature and show no signs of being hammered in a shop somewhere (which you might do if the fan interfered with the shroud).
Is this clearly a modification to the fan? Or were some curved and some not? And if these tips shouldn't be curved, what would the best process be to restore them to their proper configuration without damaging the fan in any way?
This piece was removed from a '71 LS-5 with C60.
