Help! Help! I have read the previous threads on this subject but to no avail. Have a 1969 big block and upon start-up, the wiper door, followed by the headlights both pop up momentarily and then retract once enough vacuum builds. All the vacuum lines are new and routed correctly. Check valve and filter are good. I have checked and double checked all the connections. The system works perfectly as designed while the engine is running. My guess is I have a leaking valve, actuator or relay....??????
While the wipers were sitting idle on the windshield (set the override), I did notice that the wiper arm valve "leaks air" significantly from the plunger as well as the vent (can cover the vent and the valve still releases air). However, I do not notice the venting while the wiper blade is in contact with the valve plunger. Could this be leaking enough in both positions to be causing my problem? I did by-pass the valve by connecting the 2 lines together but had the same result. Should also mention that a few minutes after engine shut-down, the wiper door will lift slightly.
Any ideas? Any simple procedure for isolating and testing individual components? Arrgh......!!!!
Thanks!!!!
Vince
#33415
Thanks!!!!
Vince
#33415
