'67 roadster dashboard question - NCRS Discussion Boards
  • Jim M.
    • January 1, 1999
    • 3
    I am removing the dashboard, what is holding the bottom most portion to floor?
  • Russ S.
    • April 30, 1982
    • 2163
    Re: '67 roadster dashboard question
    The dash is bonded to a U shaped fiberglass bracket that is mounted to the floor. Carefully separate the two.
    • Stephen L.
      • May 31, 1984
      • 3162
      You might try a wide blade putty knife and drive it down the inside of the dash to separate the dash from the bracket. It probably won't take much effort to separate the two....
